Best answer by lbrooks
Here are the steps to delete connections for Equinix Fabric
  1. Log in to the Equinix Fabric portal.
  2. From the Connections menu, select Connections Inventory
  3. Click the connection you want to delete. The Connection Details will display.
  4. Click Delete Connection.
  5. A Delete Connection prompt will display. Click Yes, Delete.
1 reply
lbrooksAuthorAnswer
August 10, 2022
March 25, 2025
And what if "Delete Connection" is grayed out? And hovering over the button says "You do not have permission to delete Connections. Request this access from your organization's primary administrator." Yet the connection is in a "Pending Interface Configuration" state...
March 31, 2025
Hi Ed,
Regardless of the configuration state, you should be able to delete the connection if you have the proper permissions. I just tested and I am able to delete connections with "pending interface configuration" state.  This list shows what permissions are needed in order to delete connections.
https://docs.equinix.com/en-us/Content/IAM/iam-roles-permission-reference.htm
