Mar 16, 2022 8:37 PM UTC
Solved
What do I do after purchasing a Network Edge virtual device?
I purchased my Network Edge virtual device. What is the next step to get it setup?
Answer
Mar 16, 2022 8:42 PM UTC
Once you've purchased the Network Edge service, the next step is making the Equinix Fabric virtual connections.
To do this, log into the ECP portal and click the "Create Connection" button. Next select the destination, location, and Network Edge device, just as you would for a physical port. Finally click submit your order and confirm the details. A success message should be displayed.
Provisioning and fulfillment should be complete in less than 10 minutes.
1 reply
Answer
