Shannon
Community Manager
Dec 12, 2022 8:16 PM UTC
Network Edge 2022.6
Network Edge 2022.6
This release of Network Edge includes more Solution Builder enhancements, sub-interface support, and the addition of Aviatrix Edge.
Solution Builder Enhancements
Design your multi-cloud network solution with the Solution Builder. Drag and drop your Network Edge and Equinix Fabric connections, into a solution diagram. You can then generate and download a pricing estimate for your end-to-end solution. We have added support for Bring Your Own Connection (BYOC), redundant devices, Device Link Group (DLG) and multi-currency.
Sub-Interface Support
Network Edge now supports sub-interface to a physical port in your colocation. Simplify your network design by trunking multiple VLAN tagged traffic over a single virtual connection.
New Certified Virtual Network Functions (VNF) Imager Versions
As part of an ongoing effort to validate and certify images from VNF vendors, this new chart will provide current and new certifications, as well as those planned for retirement.
Aviatrix Edge
Aviatrix Edge is now available in the Equinix Marketplace. Aviatrix Edge creates a high-performance encrypted connection to the cloud using the Equinix Fabric for private cloud networking.
You can find additional resources on Product Documentation and Product Readiness.
Product Documentation – https://docs.equinix.com
Product Readiness – https://readiness.equinix.com
