New Participant
Apr 21, 2025 5:12 PM UTC
Solved
Issues deploying Equinix Connections
I have managed to use several terraform modules without problem. I have used the palo alto cloudgenix vm modules, palo alto firewalls modules, device link modules, and fabric cloud router module. All work okay on the lastest version of equinix/equinix.
However as I dive into other connections I get a lot version issues. For example.
Leveraging the cloud-router-port connection.
https://registry.terraform.io/modules/equinix/fabric/equinix/latest/examples/cloud-router-2-port-connection
This would be used to connect the cloud router to the pa firewall mgmt interface. Documentation covers the following version.
required_providers {
equinix = {
source = "equinix/equinix"
version = ">= 2.9.0" } } }
But code doesnt work without this version
terraform {
    equinix = {
      version = "~> 1.26.0"
When using new versions error occurs.
Failure. Ive redone this several times in my code base.
ephemeral.aws_secretsmanager_secret_version.equinix_iac_credentials: Opening...
ephemeral.aws_secretsmanager_secret_version.equinix_iac_credentials: Opening complete after 0s
module.equinix_deployment.module.fw-mgmt-to-fcr-connection-ch-1a.equinix_fabric_connection.this: Creating...
│ Error: 400 Bad Request Code: EQ-3142558, Message: Json syntax error, please check request body, Details: Unknown json property : aSide.accessPoint.router.package.code. Unexpected value ''
│   with module.equinix_deployment.module.fw-mgmt-to-fcr-connection-ch-1a.equinix_fabric_connection.this,
│   on ..\..\modules\cloud-router-2-port-connection\main.tf line 1, in resource "equinix_fabric_connection" "this":
│    1: resource "equinix_fabric_connection" "this" {
I can get past this error and deploy the connection with an older version but then run into version issues when attempting to leverage the virtual-device-2-eia-connection
https://registry.terraform.io/modules/equinix/fabric/equinix/latest/examples/virtual-device-2-eia-connection
here the primary problem is that on older versions. there is no resource virtual-device-connection. only fabric-device-connection.
One thought is to completely separate the fabric cloud router to port module
Here is the original cloud router to port module
main.tf
  name      = var.connection_name
  type      = var.connection_type
  bandwidth = var.bandwidth
  notifications {
    type   = var.notifications_type
    emails = var.notifications_emails
  a_side {
    access_point {
      type = "CLOUD_ROUTER"
      router {
        uuid = var.aside_fcr_uuid
  z_side {
    access_point {
      type = var.zside_ap_type
      virtual_device {
        type = var.zside_vd_type
        uuid = var.zside_vd_uuid
      interface {
        type = var.zside_interface_type
        id   = var.zside_interface_id
      location {
        metro_code = var.zside_location
  order {
    purchase_order_number = var.purchase_order_number
variables
variable "connection_name" {
  type        = string
  description = "Name of the Fabric connection"
variable "connection_type" {
  type        = string
  description = "Type of the Fabric connection (e.g., IP_VC)"
variable "bandwidth" {
  type        = number
  description = "Connection bandwidth in Mbps"
variable "notifications_type" {
  type        = string
  default     = "ALL"
  description = "Notification type"
variable "notifications_emails" {
  type        = list(string)
  description = "Emails for notifications"
variable "purchase_order_number" {
  type        = string
  default     = ""
variable "aside_fcr_uuid" {
  type        = string
  description = "UUID of the FCR device"
variable "zside_ap_type" {
  type        = string
  default     = "VD"
variable "zside_vd_type" {
  type        = string
  default     = "EDGE"
variable "zside_vd_uuid" {
  type        = string
variable "zside_interface_type" {
  type        = string
  default     = "NETWORK"
variable "zside_interface_id" {
  type        = number
variable "zside_location" {
  type        = string
versions.tf
terraform {
    equinix = {
module
module "fw-mgmt-to-fcr-connection-ch-1a" { #FCR Router to FW Management Interface Connection
  source                   = "../../modules/cloud-router-2-port-connection"
  connection_name          = "fcr-2-fw-mgmt-ch"
  connection_type          = "IP_VC"
  bandwidth                = 50
  notifications_type       = "ALL"
  notifications_emails     = var.notifications
  purchase_order_number    = "mgmt-connection"
  #aside Fabric Cloud Router
  aside_fcr_uuid           = module.fcr_ch.id
  #zside Palo aAlto Firewall
  zside_ap_type            = "VD" #Virtual Device
  zside_vd_type            = "EDGE"
  zside_vd_uuid            = module.pa_vm_ch.id
  zside_interface_type     = "NETWORK"
  zside_interface_id       = 1 # Palo Alto Firewall Management Port
  zside_location           = "CH" #metro code
Employee
Apr 28, 2025 11:22 PM UTC
Hi @mikecalabrese , patch fix has been released in https://github.com/equinix/terraform-provider-equinix/releases/tag/v3.7.0
You'll just need to avoid v3.6.0 version for cloud router connections.
Thank you so much for your patience!
Employee
Apr 21, 2025 9:28 PM UTC
Hi @mikecalabrese , thanks for sharing the details around your challenge with the modules. I'm taking a look into this to see if I can recreate the issue. Once I've got a handle on this I'll reply with further guidance.
New Participant
Apr 22, 2025 3:00 PM UTC
thanks Tim!
Employee
Apr 25, 2025 12:05 AM UTC
Hi @mikecalabrese , I've finished the RCA on this. There's improved input validation in the last global release of the API layer and the Terraform Provider needs a bug fix to account for it.
This will require a version update from the Terraform Provider once I have that fix completed. I'll reply here with the version as soon as it's ready.
Thank you for your patience while we get this resolved!
Employee
Apr 28, 2025 7:42 PM UTC
Hi @mikecalabrese , my RCA was off. This was an upstream issue in our client interface generation. A previous version of Terraform (<=v03.5.0) will provide a temporary solution to unblock you until I can release the next version. Only v3.6.0 should continue to give you any issues.
Still working on releasing the bug fix.
Employee
