Employee
Jun 29, 2023 10:42 PM UTC
Have you used Network Edge Solution Builder?
Have you used Solution Builder to create a design that is so spectacular, you can't wait to share it with your colleagues? Check out the Sharing Your Solution section on the Solution Builder page in our documentation to learn how to share your designs.
1 reply
Employee
Jul 12, 2023 8:33 PM UTC
I just played with the Solution Builder. I liked the drag-and-drop interface and the bring-your-own-connection feature to connect a WAN or LAN network to an Equinix IBX data center. Thanks for sharing.
