Employee
Apr 22, 2025 3:38 PM UTC
How to Add a Purchase Order to a Fabric Virtual Connection
In this video, we'll show you how to add a purchase order while creating a new Fabric Virtual Connection. This new feature enhances our purchase order option, allowing the user to add an existing purchase order to a new virtual connection. This purchase order option is currently available for AWS, GCP, Oracle, and Azure Quick Connect. We'll guide you through the normal quick connect workflow and then highlight the new purchase order feature in the "Additional Information" section.
Create a new virtual connection in the Fabric Portal: https://fabric.equinix.com/
