Answer
Aug 22, 2022 5:44 PM UTC
It shouldn't take long., typically less than 5 min. Exceptions to this would be if there is a capacity limitation. Please note, the connection speed is determined by the ExpressRoute key.
 A few additional notes can be found below:
Traffic continues to flow at the previous lower speed when the bandwidth upgrade is being configured until the upgrade on both the A-side and Z-side of the circuit is successfully completed.
Increase Azure ExpressRoute Bandwidth
Create and Modify an ExpressRoute Circuit.
1 reply
Answer
