Employee
July 15, 2026
Sovereignty Elevated: Geo Zone Enforcement Now Extends to the Network Edge
  • July 15, 2026
  • 0 replies
  • 4 views
We are excited to announce a significant architectural evolution in our sovereignty controls. While geo-boundary enforcement has historically resided at the Fabric port level, we have successfully extended this capability down to the Network Edge virtual device itself.
This upgrade empowers customers to define and enforce Geo Zones when the Network Edge is the originating endpoint of a Fabric connection. You can now provision and validate this constraint directly via the UI or API, ensuring compatibility checks run before provisioning commits. This proactive validation removes the risk of post-deployment configuration mismatches.
This feature is live today across GCP, AWS, and Oracle Quick Connect, supporting both VD-to-Port and VD-to-CSP provisioning paths. (A note for your integration specialists: The API layer for this specific implementation is delivered by the Fabric team.)
