Employee
April 3, 2019
Solved
Cross Connect Ordering?
  • April 3, 2019
  • 1 reply
  • 37 views
I would like to know how I can place a Cross Connect Order using APIs? Any documentation link would be useful. Thanks!
Best answer by API_User
Hello,
Thank you for your inquiry!
To place a Cross Connect Order using API, basically, you will follow the same workflow as the order form on the ECP portal. You will gather proper information for your A-Side, Z-Side details, as well as provide scheduling, contact information. If you have any optional information and reference, such as purchase order, you can include as well. Then you can use the crossconnect order API (https://developer.equinix.com/catalog/crossconnectv1) to place Cross Connect order. Please note, if you do not already have the details for A-Side/Z-Side, you may use additional APIs to get those information. For example, locations API to get IBX, cage, and cabinet, etc.
For details about each crossconnect APIs, please refere to https://developer.equinix.com/catalog/crossconnectv1.
1 reply
API_UserAuthorAnswer
Employee
April 4, 2019
Hello,
