The Equinix Community will be offline for scheduled maintenance on July 31, 2024. Learn More.
What is the cost structure for Network Edge?
Solved! Go to Solution.
Network Edge includes the following priced elements. Each invoice will include these items:
Depending on what the virtual device is connected to, additional charges will apply from the other Interconnection products used.
For example, a connection from your virtual device to AWS through the cloud exchange would incur normal pricing for the Equinix Fabric. The Equinix pricing guide has further details.
A complete solution could include:
Invoice Item | Description |
Network Edge Instance |
The virtual equivalent of the cabinet you'd lease inside a Data Center. It provides the compute, storage, virtual port, internet access, and IP addressing needed to get started. |
Network Edge Device: License |
This item is on the invoice, but is only charged if Equinix provides the license (aka Subscription). |
Network Edge Instance – Additional Bandwidth |
This item displays if you need more bandwidth than the minimum that's included in the instance. |
Network EdgeInstance – Additional IP Allocation |
We can lease additional public IP address space for an additional fee. |
Equinix Fabric Virtual Connections |
Pricing is per standard Equinix Fabric rates and rules. |
Confirm pricing either online or with your account representative. If you have an account or create one, you can build a sample device with desired settings and save it before you buy and print a summary of the proposed charges. The pricing model operates the same way as the Equinix Fabric pricing model, replacing a port with a Network Edge device. As a result, the A-End, or connection requestor pays for the connections, regardless of other factors including the destination, local or remote port, or other options.
Equinix is the world's digital infrastructure company. Digital leaders harness our trusted platform to bring together and interconnect the foundational infrastructure that powers their success. We enable our customers to access all the right places, partners and possibilities they need to accelerate advantage.
