This is the third part of a series of posts highlighting the best practices for customers who require highly resilient networks in Network Edge. This entry highlights how to build resilient EVP-LAN connections in Network Edge.
- EVP-LAN is another method to connection Network Edge devices
- EVP-LANs differ from DLGs in that they connect to Network Edge devices and Fabric ports
- All EVP-LAN connections go to the Fabric, even for devices in the same metro--this is in contrast to DLGs which can be local or remote.
- As of November 2023, multiple NE devices in the same metro can be part of the same EVP-LAN network, removing the previous restriction of a single NE device per metro.
- Customers that require maximum resiliency should deploy additional EVP-LANs that span both the Primary and Secondary Fabric networks
- The same logic applies for EVP-LANs such that they should spread across Primary and Secondary Fabric planes
- The current maximum bandwidth for all EVP-LAN connections in the same metro is 10GB. This may change in the future.
Redundant Devices
- For proper resiliency, each device in the Redundant Device pair will require a single connection to two different EVP-Networks
- The Primary device on the Primary plane will use the Primary Fabric switch
- The Secondary device on the Secondary plane will use the Secondary Fabric switch
![MasonHarris_0-1700483899147.png MasonHarris_0-1700483899147.png](/t5/image/serverpage/image-id/701i164E160CDC8494E2/image-size/large?v=v2&px=999)
Clustered Devices
- Clustered devices are different in that the workflow allows connections to be built to either the Primary or Secondary Fabric
- For proper resiliency, each node in the Cluster will require a single connection to two different EVP-Networks
![MasonHarris_1-1700483962424.png MasonHarris_1-1700483962424.png](/t5/image/serverpage/image-id/702i6441ABAF45CBE795/image-size/large?v=v2&px=999)
The next post will cover the best practices for creating resilient Fabric Virtual Connections. You can read the first part of this series here.
