Forum Discussion
MasonHarris
2 years agoEquinix Product Manager
Building Highly Resilient Networks in Network Edge - Part 3 - EVP-LANs
This is the third part of a series of posts highlighting the best practices for customers who require highly resilient networks in Network Edge. This entry highlights how to build resilient EVP-LAN connections in Network Edge.
- EVP-LAN is another method to connection Network Edge devices
- EVP-LANs differ from DLGs in that they connect to Network Edge devices and Fabric ports
- All EVP-LAN connections go to the Fabric, even for devices in the same metro--this is in contrast to DLGs which can be local or remote.
- As of November 2023, multiple NE devices in the same metro can be part of the same EVP-LAN network, removing the previous restriction of a single NE device per metro.
- Customers that require maximum resiliency should deploy additional EVP-LANs that span both the Primary and Secondary Fabric networks
- The same logic applies for EVP-LANs such that they should spread across Primary and Secondary Fabric planes
- The current maximum bandwidth for all EVP-LAN connections in the same metro is 10GB. This may change in the future.
Redundant Devices
- For proper resiliency, each device in the Redundant Device pair will require a single connection to two different EVP-Networks
- The Primary device on the Primary plane will use the Primary Fabric switch
- The Secondary device on the Secondary plane will use the Secondary Fabric switch
Clustered Devices
- Clustered devices are different in that the workflow allows connections to be built to either the Primary or Secondary Fabric
- For proper resiliency, each node in the Cluster will require a single connection to two different EVP-Networks
The next post will cover the best practices for creating resilient Fabric Virtual Connections. You can read the first part of this series here.
No RepliesBe the first to reply
Related Content
- 5 months ago
Recent Discussions
Featured Places
Discussions
Engage with industry experts, share insights, ask questions, and grow your network.Ideas
We're listening! Submit your ideas to shape the future of Equinix!Groups
Ready to collaborate? Join a Group or upcoming beta program.What's New
Stay ahead with the latest from Equinix. Discover new product announcements, insightful tutorials, and practical use cases.Events
Your Guide to Upcoming Events - Online, Hybrid, and In-Person!
