Forum Discussion
Jantzen's avatar
Jantzen
Equinix Employee
3 years ago
Solved
How long will it take to upgrade the speed of my Azure primary and secondary connections?
I need to upgrade my primary and secondary Azure ExpressRoute connections. How long will it take to upgrade them?
  • It shouldn't take long., typically less than 5 min. Exceptions to this would be if there is a capacity limitation. Please note, the connection speed is determined by the ExpressRoute key.
     A few additional notes can be found below:
    Traffic continues to flow at the previous lower speed when the bandwidth upgrade is being configured until the upgrade on both the A-side and Z-side of the circuit is successfully completed.
    Increase Azure ExpressRoute Bandwidth
    Create and Modify an ExpressRoute Circuit.
1 Reply
Replies have been turned off for this discussion
  • Jantzen's avatar
    Jantzen
    Equinix Employee
Featured Places
  • Node avatar for Discussions
    Discussions
    Engage with industry experts, share insights, ask questions, and grow your network.
  • Node avatar for Ideas
    Ideas
    We're listening! Submit your ideas to shape the future of Equinix!
  • Node avatar for Groups
    Groups
    Ready to collaborate? Join a Group or upcoming beta program.
  • Node avatar for What's New
    What's New
  • Node avatar for Events
    Events
    Your Guide to Upcoming Events - Online, Hybrid, and In-Person!
