Knowledge Base Article
How to set up Datadog
This guide will provide step-by-step instructions on how to set up a Datadog Service, enabling you to easily view Fabric Metrics. You can use the API Key and Application Key Details in the following POST fabric/v4/streamSubscriptions request.
curl -X 'POST' 'https://api.equinix.com/fabric/v4/streams/<streamId>/subscriptions' \
"type": "STREAM_SUBSCRIPTION",
"name": "<datadog_subscription_name>",
"description": "<datadog_subscription_desc>",
"sink": {
"host": "https://<datadog_site_parameter>",
"type": "DATADOG",
"credential": {
"type": "API_KEY",
"apiKey": "<datadog_api_key>"
"settings": {
"applicationKey": "<datadog_application_key>"
Step-by-Step Instructions
1. Create an API Key
• Log in to your Datadog, navigate to Profile Organizations.
• Under the Organizations Settings, click API Keys.
• Click New Key.
1.1 Provide a Name for the API Key
- API Key Name: Provide a name to identify the API Key.
- Click Finish to continue.
2. Create an Application Key
- Under Organization Settings, click Application Keys.
- Click New Key.
2.1 Provide a Name for the Application Key
- Provide a name to identify the Application Key.
3. Save the Datadog API and Application Key
- Ensure that the API and Application Keys generated during this process are saved securely. The API and Application Keys are required for further integration or data ingestion processes.
3.1 Copy the API and Application Keys
- Once the setup is complete, an API and Application Key value will be generated.
- Copy the API and Application Key to your clipboard, as it will be needed later for the POST streamSubscription API in Stream Observability.
3.2 Start receiving Fabric Metrics in Datadog
- Navigate to Metrics Explorer and search the Fabric Metrics for Observability.
| Disclaimer: These guides are unofficial and for general reference only. For specific details, please consult the respective provider’s documentation. |
Updated 5 months ago
Version 3.0vdamojipurapu1
Equinix Product Manager
Joined June 05, 2025
