Need to design a multi-cloud solution? Use Solution Builder
  • December 12, 2022
  • 0 replies
  • 2 views
It’s an easy way to design your multi-cloud network solution. Just drag and drop your Network Edge and Equinix Fabric connections, into a solution diagram, to generate and download a pricing estimate for your end-to-end solution.
Drop a comment below if you've tried this feature ⬇️
Check out the latest resources from Product Documentation and Product Readiness below:
Product Documentation – https://docs.equinix.com
Product Readiness – https://readiness.equinix.com
