Forum Discussion
API_User's avatar
API_User
Equinix Employee
3 years ago
Filter "portName" on connection list not working
Hello, for the endpoint GET https://api.equinix.com/ecx/v3/l2/seller/connections
I use it with the profileId filter and I get back many results. I go from page to page to list the connection I have on one specific port.
I would like to reduce those calls using the filter portName. However the result is always empty :
    "isFirstPage": true,
    "isLastPage": true,
    "totalCount": 0,
    "pageSize": 20,
    "content": [],
    "pageNumber": 0
Have anyone succeeded in getting this to work ?
Best regards,
  • API_User's avatar
    API_User
    Equinix Employee
    Hello,
    Thx for the feedbacks !
    Yes i'm the seller in this case.
  • API_User's avatar
    API_User
    Equinix Employee
    To confirm, are you the seller (z side) in this scenario? If not, that may be part of the issue. You can try using the /ecx/v3/l2/buyer/connections endpoint and using the buyerPortUUID query parameter - likely a little less error prone than using buyerPortName.
  • API_User's avatar
    API_User
    Equinix Employee
    Regarding the portName search not working,
    /ecx/v3/l2/seller/connections?pageSize=&pageNumber=&portName=OVH-PA3-PA4-ECX_PRI-21365958
    I am looking into it and will respond soon. the earlier URL with portName had a typo, please ignore that.
  • API_User's avatar
    API_User
    Equinix Employee
    This is the other URL I tried
    /ecx/v3/l2/seller/connections?pageSize=&pageNumber=&portname=OVH-PA3-PA4-ECX_PRI-21365958&profileId=9e17ad3e-66bb-459e-9373-5d9c0146512c
  • API_User's avatar
    API_User
    Equinix Employee
    Hi, this is Equinix developer responding.
    I have tried:
    /ecx/v3/l2/seller/connections?pageSize=&pageNumber=&profileId=9e17ad3e-66bb-459e-9373-5d9c0146512c
    And the response is being populated with correct values in response with field names sellerServiceUUID(profileId) and zSidePortName(portname).
    I used the info of user that created the service profile to perform the test, as i don't have your user details.
    Please can you create a ticket with Equinix support so we can look into your user detail permissions for viewing the connections.
    Thanks.
  • API_User's avatar
    API_User
    Equinix Employee
    Hello and thanks for the feedback.
    Here is an example:
    • GET /ecx/v3/l2/seller/connections?profileId=9e17ad3e-66bb-459e-9373-5d9c0146512c
      • Returns some connections, example:
      • uuid: 91d0050d-903e-4f5c-881c-cdc7b748707c
      • zSidePortName: OVH-PA3-PA4-ECX_PRI-21365958
    If I do:
    GET https://api.equinix.com/ecx/v3/l2/seller/connections?portName=OVH-PA3-PA4-ECX_PRI-21365958&profileId=9e17ad3e-66bb-459e-9373-5d9c0146512c
    or
    GET /ecx/v3/l2/seller/connections?portName=OVH-PA3-PA4-ECX_PRI-21365958
    Then the result is empty
        "isLastPage": true,
        "totalCount": 0,
        "pageSize": 20,
        "content": [],
        "pageNumber": 0
Featured Places
  • Node avatar for Discussions
    Discussions
    Engage with industry experts, share insights, ask questions, and grow your network.
  • Node avatar for Ideas
    Ideas
    We're listening! Submit your ideas to shape the future of Equinix!
  • Node avatar for Groups
    Groups
    Ready to collaborate? Join a Group or upcoming beta program.
  • Node avatar for What's New
    What's New
  • Node avatar for Events
    Events
    Your Guide to Upcoming Events - Online, Hybrid, and In-Person!
